TwinTurbo.NET: Nissan 300ZX forum - Re: The fuel temp would be in the ConZult logs
Subject Re: The fuel temp would be in the ConZult logs
Posted by Christopher on May 25, 2003 at 12:55 AM
  This message has been viewed 101 times.
In Reply To The fuel temp would be in the ConZult logs posted by Christopher on May 25, 2003 at 12:16 AM
Message As far as I can find max voltage the MAF is capable of is 5.12v but apparently its inaccurate at that level so 5v is max. Are you running dual MAF? If not its possible you're maxing the MAF. In reviewing the ConZult logs do you peak at 4.9v prior to letting off? That would possibility be an indicator.
Christopher
